Support
Workflow: Enabling Manual Approval
Follow
The Automox patch policy has the ability to enable a manual approval process for your patches. When you turn on a manual approval process, you can conveniently approve and reject new patches on the Needs Approval category of the dashboard:
The approval process is turned on at the patch policy level. By specifying "Manually Approve Patches" in the Patching Scope, all new patches will show up in Needs Approval. When you Accept or Reject patches from the dashboard, you can always see a list of approved/rejected patches and modify the approval status on the patch policy screen:
0 Comments
