Prerequisites
Configure your desired products and classifications, languages, synchronization schedule, and Automatic approvals. These settings will be specific to your environment
Configure Update Files and Languages (Local Caching)
  • The “Update Languages” tab of this wizard will be specific to your environment
  • The “Update Files” tab should be configured as seen below:
Automatic Approvals
  • Update Rules - This will be specific to your environment. The goal here is to have WSUS automatically approve any update it finds, as such, this rule should mirror the products and classifications which you have configured on your WSUS server
  • Advanced - Should be specific to your environment
Configure Endpoints
  • Configure WSUS Server in the Automox Console for desired groups
  • Disable OS Automatic Updates in the Automox Console for desired groups (recommended for all groups
Maintaining your WSUS Environment
  • Periodically remove unneeded update files using the following command:
  • Invoke-WsusServerCleanup -CleanupObsoleteComputers -CleanupUnneededContentFiles -CompressUpdates -CleanupObsoleteUpdates -DeclineExpiredUpdates -DeclineSupersededUpdates
  • Recommend putting this in a scheduled task to run at least once a month
Did this answer your question?
